vserver consistency-group snapshot start
Start a 2 phase Snapshot copy for a consistency group
The vserver consistency-group snapshot start command starts a 2-phase Snapshot copy of a specified consistency group.
-vserver <Vserver Name>- Vserver Name-
This parameter specifies the Vserver that contains the consistency group where the Snapshot copy is to be started.
-consistency-group <text>- Consistency Group Name-
This parameter specifies the consistency group where a Snapshot copy is to be started.
-snapshot <snapshot name>- Snapshot Copy Name-
This parameter specifies the name of the Snapshot copy that is to be started.
[-parent-consistency-group <text>]- Parent Consistency Group Name-
This parameter specifies the parent consistency group where a Snapshot copy is to be started for a child consistency group.
[-consistency-type {crash|application}]- Consistency Type-
This parameter optionally specifies the consistency level of a Snapshot copy. The default value is
crash. [-comment <text>]- Comment-
This parameter optionally specifies the comment associated with a Snapshot copy.
[-snapmirror-label <text>]- Snapmirror Label-
This parameter optionally specifies the label associated with a Snapshot copy.
[-start-timeout <integer>]- Timeout for 2-phase snapshot-
This parameter optionally specifies the timeout limit for the Snapshot copy to be started. The default value is
7seconds. [-write-fence {true|false}]- Take write fence-
This parameter specifies if a write fence is taken on the volumes in the consistency group while creating a Snapshot copy.
+ The following example starts a 2-phase Snapshot copy named snap1 on a consistency group named cg1 on a Vserver named vs0. The Snapshot copy has start-timeout set to "60", a comment "2-phase", a Snapmirror label "Label" and is crash-consistent.
cluster1::> vserver consistency-group snapshot start -vserver vs0 -consistency-group cg1 -parent-consistency-group "-" -snapshot snap1 -start-timeout 60 -comment "2-phase" -snapmirror-label "Label" -consistency-type crash
(vserver consistency-group snapshot start)
+ The following example starts a 2-phase Snapshot copy named snap2 on a child consistency group named childCg in parent consistency group parentCg on a Vserver named vs0. The Snapshot copy has start-timeout set to "90".
cluster1::> vserver consistency-group snapshot start -vserver vs0 -consistency-group childCg -parent-consistency-group parentCg -snapshot snap2 -start-timeout 90
