security login duo group delete
Delete a Duo Group Configuration
The security login duo group delete command deletes the specied group.
-vserver <vserver name>- Vserver-
This parameter optionally specifies the Vserver of the Duo group that is being deleted.
-group-name <text>- Group Name-
This parameter optionally specifies the group name that is being deleted.
The following command deletes the group "test" from the Vserver "vs1".
cluster1::> security login duo group delete -vserver vs1 -group-name test
