ONTAP commands
storage aggregate object-store show-resync-status
Display object store mirror resync progress
The storage aggregate object-store show-resync-status command displays information about the resync progress for mirror object stores attached to a FabricPool.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-aggregate <aggregate name>] - Aggregate
If this parameter is specified, the command displays information only about the specified aggregates.
[-primary-object-store-name <text>] - Primary Object Store Name
If this parameter is specified, the command displays information only about aggregates whose primary object store configuration name matches the specified names.
[-mirror-object-store-name <text>] - Mirror Object Store Name
If this parameter is specified, the command displays information only about aggregates whose mirror object store configuration name matches the specified names.
[-percent-complete <percent>] - Resync Complete Percentage
If this parameter is specified, the command displays information only about aggregates whose mirror object store resync progress percentage matches the specified value.
The following example displays resync progress for all aggregates with mirror object stores which are not in sync:
cluster1::>storage aggregate object-store show-resync-status
