vserver vscan on-access-policy disable
Disable an On-Access policy
The vserver vscan on-access-policy disable
command disable an On-Access policy for the specified Vserver.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver on which you want to disable an On-Access policy. The Vserver administrator can disable On-Access policies created within the scope of the Vserver and can also disable an On-Access policy created by the cluster administrator. The cluster administrator can disable On-Access policies for any Vserver.
-policy-name <Policy name>
- Policy-
This parameter specifies the name of the On-Access policy you want to disable.
The following command disable an On-Access policy on specified Vserver.
cluster1::> vserver vscan on-access-policy disable -vserver vs1 -policy-name new cluster1::> vserver vscan on-access-policy show -instance -vserver vs1 -policy-name new Vserver: vs1 Policy: new Policy Status: off Policy Config Owner: vserver File-Access Protocol: CIFS Filters: scan-ro-volume Mandatory Scan: on Max File Size Allowed for Scanning: 4GB File-Paths Not to Scan: \vol\temp File-Extensions Not to Scan: txt
