vserver export-policy show
Display a list of rule sets
The vserver export-policy show command displays the following information:
Vserver name
Export policy name
Policy ID (diagnostic privilege level only)
[-fields <fieldname>,…] -
If you specify the
-fieldsparameter, the command only displays the fields that you specify. - |
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all entries. [-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays a list of export policies that are located on the Vserver that you specify.
[-policyname <export policy name>]- Policy Name-
If you specify this parameter, the command displays only the export policy or sets that match the specified name.
The following example displays a list of all export policies:
vs1::> vserver export-policy show VServer Policy Name --------------- ------------------- vs0 default_expolicy vs0 read_only_expolicy vs1 default_expolicy vs1 test_expolicy 4 entries were displayed.
