Command reference
vserver export-policy show
Display a list of rule sets
The vserver export-policy show command displays the following information:
  • Vserver name
  • Export policy name
  • Policy ID (diagnostic privilege level only)
{ [-fields <fieldname>,…​]
If you specify the -fields parameter, the command only displays the fields that you specify.
| [-instance ] }
If you specify the -instance parameter, the command displays detailed information about all entries.
[-vserver <vserver name>] - Vserver
If you specify this parameter, the command displays a list of export policies that are located on the Vserver that you specify.
[-policyname <export policy name>] - Policy Name
If you specify this parameter, the command displays only the export policy or sets that match the specified name.
The following example displays a list of all export policies:
vs1::> vserver export-policy show
VServer          Policy Name
vs0              default_expolicy
vs0              read_only_expolicy
vs1              default_expolicy
vs1              test_expolicy
4 entries were displayed.
