The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
security key-manager external gcp rekey-internal
PDF of this doc site
Creating your file...
Your file is ready
Rekey an internal key of the Vserver
This command rekeys the internal Vserver key hierarchy by changing the SVM key encryption key (KEK). Upon successful completion of the command, all keys in the Vserver key hierarchy will be protected by the new top-level KEK.
-vserver <Vserver Name>
- Vserver (privilege: advanced)-
This parameter specifies the Vserver for which ONTAP should rekey the SVM KEK.
The following command rekeys the SVM KEK for data Vserver v1.
cluster-1::> security key-manager external gcp rekey-internal -vserver v1
