security anti-ransomware volume disable
- PDF of this doc site
Creating your file...
Your file is ready
Disable anti-ransomware on a volume
The security anti-ransomware volume disable
command disables anti-ransomware monitoring on a volume.
-vserver <vserver name>
- Vserver Name-
Anti-ransomware monitoring is disabled on volumes that match the values for the Vserver and volume parameters. If only one data Vserver exists, you do not need to specify this parameter.
-volume <volume name>
- Volume Name-
Anti-ransomware monitoring is disabled on volumes matching the parameter value.
