      security anti-ransomware volume disable
Disable anti-ransomware on a volume
The security anti-ransomware volume disable command disables anti-ransomware monitoring on a volume.
- -vserver <vserver name>- Vserver Name
Anti-ransomware monitoring is disabled on volumes that match the values for the Vserver and volume parameters. If only one data Vserver exists, you do not need to specify this parameter.
- -volume <volume name>- Volume Name
Anti-ransomware monitoring is disabled on volumes matching the parameter value.
 PDFs
PDFs
