security anti-ransomware volume disable
Disable anti-ransomware on a volume
The security anti-ransomware volume disable command disables anti-ransomware monitoring on a volume.
-vserver <vserver name>- Vserver Name-
Anti-ransomware monitoring is disabled on volumes that match the values for the Vserver and volume parameters. If only one data Vserver exists, you do not need to specify this parameter.
-volume <volume name>- Volume Name-
Anti-ransomware monitoring is disabled on volumes matching the parameter value.
[-auto-enabled-volumes-only {true|false}]- Option to disable only on auto enabled volumes (privilege: advanced)-
Anti-ransomware monitoring will be disabled on volumes matching the parameter value.
