security key-manager external gcp check
PDF of this doc site
Creating your file...
Show detailed status of the Google Cloud KMS configurations
This command displays the Google Cloud Key Management Service (KMS) status.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node (privilege: advanced)-
If this parameter is specified then the command displays only the Google Cloud KMS status for the given node.
[-vserver <Vserver Name>]
- Vserver Name (privilege: advanced)-
If this parameter is specified then the command displays only the Google Cloud KMS status for the given Vserver.
[-category <Categories for Cloud KMS status check>]
- Component (privilege: advanced)-
If this parameter is specified then the command displays only the Google Cloud KMS status for the given category.
Category Description -------- ----------- service_reachability Cloud KMS Reachability ekmip_server Embedded KMIP Server Reachability kms_wrapped_key_status Status of KMS Wrapped Keys On Cluster
[-status <Status Check>]
- Status (privilege: advanced)-
If this parameter is specified then the command displays only the Google Cloud KMS status entries matching the given status.
OK FAILED UNKNOWN
[-detail <text>]
- Status Details (privilege: advanced)-
This field displays the detailed status message, if available.
The example below displays the status of all components of all Google Cloud KMS configured on the node.
cluster-1::> security key-manager external gcp check -node vsim1 Vserver: vs1 Node: vsim1 Category: service_reachability Status: OK Category: ekmip_server Status: OK Category: kms_wrapped_key_status Status: OK
