The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver nvme modify
PDF of this doc site
Creating your file...
Your file is ready
Modify NVMe service configuration
The vserver nvme modify
command modifies an NVMe service configuration on a Vserver.
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver for the NVMe service.
[-status-admin {down|up}]
- Administrative Status-
Specifies the configured administrative status of a service. If you set this parameter to
down
, the Vserver will not serve NVMe traffic. [-mdns-service-discovery-enabled {true|false}]
- Use Multicast DNS Service Discovery (privilege: advanced)-
Specifies the configured mDNS service discovery status of a service. If you set this parameter to
false
, the Vserver will not advertise NVMe-IP LIFs over Multicast DNS. The default value for create istrue
cluster1::*> vserver nvme modify -vserver vs_1 -status-admin down
Sets the administrative status of the NVMe service on Vserver vs_1
to down
