statistics system show
System utilization metrics for the cluster
This command continuously displays performance data for cluster at a regular interval. The command output displays data in the following columns:
System - cluster name.
CPU (%) - CPU utilization.
Total Ops - total number of operations per second.
Latency(ms) - average latency for an operation in milliseconds.
- [-system <text>]- System
Selects the cluster for which you want to display performance data.
- [-sort-key <text>]- Column to Sort By
If this parameter is specified, the command displays statistics sorted by the specified column.
- -interval <integer>- Interval
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
- -iterations <integer>- Iterations
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
- -max <integer>- Maximum Number of Instances
Specifies the maximum number of systems to display. The default setting is 25.
The following example displays system statistics:
cluster1::> statistics system show
cluster1 : 12/31/2013 16:00:04
         CPU *Total Latency
  System (%)    Ops    (ms)
 Cluster  76    113       -
 PDFs
PDFs
