storage array port remove
Remove a port record from an array profile.
The storage array port remove command removes a port from the array database. You might want to remove ports that are no longer connected to the clustered node. Port information can change after hardware replacement, rezoning, or similar configuration activities. The database retains the records about previous ports unless you remove the information.
- -name <text>- Name
Selects the array ports that match this parameter value. The storage array name is either generated by Data ONTAP or assigned by the user.
- { [-wwnn <text>]- WWNN
- [-wwpn <text>]- WWPN
- | [-target-iqn <text>]- Target IQN
- [-tpgt <integer>]- TPGT }
This command removes a port record from the array profiles database.
cluster1::> storage array port remove -name HITACHI_DF600F_1 -wwnn 50060e80004291c0 -wwpn 50060e80004291c0
 PDFs
PDFs
