storage stackmon show
Display stackmon information
The storage stackmon show command displays information for stackmon on all nodes. If no parameters are specified, the default command displays the following information:
  • Node
  • State
  • Paused
To display detailed information, use the -node parameter.
{ [-fields <fieldname>,…​]
Displays output in column style about the specified fields.
| [-instance ] }
Displays expanded information for stackmon on all nodes. If a node is specified, then this parameter displays the same detailed information for the specified port as does the -node parameter.
[-node {<nodename>|local}] - Node (privilege: advanced)
Displays the stackmon information for the the specified node.
[-state {init|processing|stable|failed-reconcile}] - State (privilege: advanced)
Displays the stackmon information that matches the specified state.
[-paused {true|false}] - Paused (privilege: advanced)
Displays the stackmon information that matches the specified value.
[-timer-delay <integer>] - Timer Delay (privilege: advanced)
Displays the stackmon information that matches the specified timer-delay value.
The following example displays stackmon information for all nodes:
cluster1::> storage stackmon show
Node                  State            Paused
node1                 stable           false
node2                 stable           false
node3                 stable           false
node4                 stable           false
4 entries were displayed.
