storage stackmon show
Display stackmon information
The storage stackmon show command displays information for stackmon on all nodes. If no parameters are specified, the default command displays the following information:
Node
State
Paused
To display detailed information, use the -node parameter.
[-fields <fieldname>,…] -
Displays output in column style about the specified fields.
[-instance ]} -
Displays expanded information for stackmon on all nodes. If a node is specified, then this parameter displays the same detailed information for the specified port as does the -node parameter.
[-node {<nodename>|local}]- Node (privilege: advanced)-
Displays the stackmon information for the the specified node.
[-state {init|processing|stable|failed-reconcile}]- State (privilege: advanced)-
Displays the stackmon information that matches the specified state.
[-paused {true|false}]- Paused (privilege: advanced)-
Displays the stackmon information that matches the specified value.
[-timer-delay <integer>]- Timer Delay (privilege: advanced)-
Displays the stackmon information that matches the specified timer-delay value.
The following example displays stackmon information for all nodes:
cluster1::> storage stackmon show Node State Paused --------------------- ---------------- ------ node1 stable false node2 stable false node3 stable false node4 stable false 4 entries were displayed.
