ONTAP commands
storage stackmon show
Display stackmon information
The storage stackmon show command displays information for stackmon on all nodes. If no parameters are specified, the default command displays the following information:
  • Node
  • State
  • Paused
To display detailed information, use the -node parameter.
[-fields <fieldname>,…​]
Displays output in column style about the specified fields.
| [-instance ] (privilege: advanced) }
Displays expanded information for stackmon on all nodes. If a node is specified, then this parameter displays the same detailed information for the specified port as does the -node parameter.
[-node {<nodename>|local}] - Node (privilege: advanced)
Displays the stackmon information for the the specified node.
[-state {init|processing|stable|failed-reconcile}] - State (privilege: advanced)
Displays the stackmon information that matches the specified state.
[-paused {true|false}] - Paused (privilege: advanced)
Displays the stackmon information that matches the specified value.
[-timer-delay <integer>] - Timer Delay (privilege: advanced)
Displays the stackmon information that matches the specified timer-delay value.
The following example displays stackmon information for all nodes:
cluster1::> storage stackmon show
Node                  State            Paused
node1                 stable           false
node2                 stable           false
node3                 stable           false
node4                 stable           false
4 entries were displayed.
