The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system controller replace cancel
PDF of this doc site
Creating your file...
Your file is ready
Cancel ongoing controller replacement
The system controller replace cancel
command is used to cancel a controller replacement that is in paused state (paused-on-request, paused-on-error or paused-for-intervention). The update cannot be canceled if it is not in a paused state.
The following example displays a cancel operation:
cluster1::> system controller replace cancel Warning: The controller replacement will be canceled and any changes will have to be reverted manually. Do you want to continue? {y|n}: y Controller replacement canceled successfully.
