ONTAP 9.9.1 commands
system controller replace cancel
Cancel ongoing controller replacement
The system controller replace cancel command is used to cancel a controller replacement that is in paused state (paused-on-request, paused-on-error or paused-for-intervention). The update cannot be canceled if it is not in a paused state.
The following example displays a cancel operation:
cluster1::> system controller replace cancel
Warning: The controller replacement will be canceled and any changes will have to be reverted manually.
Do you want to continue? {y|n}: y
Controller replacement canceled successfully.
