storage pool rename
Rename storage pool
The storage pool rename
command changes the name of the storage pool.
-storage-pool <storage pool name>
- Storage Pool Name-
This parameter specifies the storage pool name.
-new-name <storage pool name>
- New Name of the Storage Pool-
This parameter specifies the new name of the storage pool.
Renaming storage pool "sp1" to "sp2"
cluster-1::> storage pool show Storage Storage Pool Type #Disks Nodes Total Size ------------------- ------- ------ ---------------- ---------- sp1 SSD 4 node-a, 10.44GB node-b cluster-1::> storage pool rename -storage-pool sp1 -new-name sp2 cluster-1::> storage pool show Storage Storage Pool Type #Disks Nodes Total Size ------------------- ------- ------ ---------------- ---------- sp2 SSD 4 node-a, 10.44GB node-b
