storage pool rename
Rename storage pool
The storage pool rename command changes the name of the storage pool.
-storage-pool <storage pool name>- Storage Pool Name-
This parameter specifies the storage pool name.
-new-name <storage pool name>- New Name of the Storage Pool-
This parameter specifies the new name of the storage pool.
Renaming storage pool "sp1" to "sp2"
cluster-1::> storage pool show
Storage
Storage Pool Type #Disks Nodes Total Size
sp1 SSD 4 node-a, 10.44GB
node-b
cluster-1::> storage pool rename -storage-pool sp1 -new-name sp2
Storage
sp2 SSD 4 node-a, 10.44GB
node-b
