Command reference
storage pool rename
Rename storage pool
The storage pool rename command changes the name of the storage pool.
-storage-pool <storage pool name> - Storage Pool Name
This parameter specifies the storage pool name.
-new-name <storage pool name> - New Name of the Storage Pool
This parameter specifies the new name of the storage pool.
Renaming storage pool "sp1" to "sp2"
cluster-1::> storage pool show
                     Storage
Storage Pool         Type    #Disks Nodes             Total Size
sp1                  SSD          4 node-a,           10.44GB
                                    node-b
cluster-1::> storage pool rename -storage-pool sp1 -new-name sp2
                     Storage
sp2                  SSD          4 node-a,           10.44GB
                                    node-b
