vserver services name-service unix-group load-from-uri
Load one or more local UNIX groups from a URI
The vserver services name-service unix-group load-from-uri command loads UNIX groups from a universal resource identifier (URI). The URI must contain group information in the UNIX /etc/group format:
group_name :password :group_ID :comma_separated_list_of_users
The command discards the value of the password field.
- -vserver <vserver>- Vserver
Use this parameter to specify the Vserver on which to locate the local UNIX groups.
- -uri {(ftp|http)://(hostname|IPv4 Address|'['IPv6 Address']')…}- URI to Load From
Use this parameter to specify the URI from which the command loads group information. The URI scheme must be either ftp(s) or http(s)
- [-overwrite {true|false}]- Overwrite Entries
Use this parameter with the value trueto specify that group information loaded from the URI should overwrite existing group information. The default value isfalse, specifying that group information loaded from the URI should not overwrite existing group information.
- [-skip-name-validation {true|false}]- Skip Name Validation
By default, Data ONTAP validates the name to ensure it complies with the following rules: -
The name contains only valid characters: 0 through 9, A through Z, a through z, "_", ".", and "-"
The name does not start with "-"
The name does not contain "$" except as the last character
 If the parameter is set to true, the name validation is skipped.
- [-foreground {true|false}]- Load Unix Groups file in the Foreground
If this parameter is set to false, the operation runs as a job in the background. Otherwise, the command does not return until the operation is complete. The default value istrue.
The following example loads group information from the URI ftp://ftp.example.com/groups onto a Vserver named vs0:
cluster1::> vserver services name-service unix-group load-from-uri -vserver vs0 -uri ftp://ftp.example.com/groups
 PDFs
PDFs
