vserver services name-service unix-group load-from-uri
Load one or more local UNIX groups from a URI
The vserver services name-service unix-group load-from-uri command loads UNIX groups from a universal resource identifier (URI). The URI must contain group information in the UNIX /etc/group format:
group_name :password :group_ID :comma_separated_list_of_users
The command discards the value of the password field.
-vserver <vserver> - Vserver
Use this parameter to specify the Vserver on which to locate the local UNIX groups.
-uri {(ftp|http|https)://(hostname|IPv4 Address|'['IPv6 Address']')…​} - URI to Load From
Use this parameter to specify the URI from which the command loads group information. The URI scheme must be either ftp(s) or http(s)
[-overwrite {true|false}] - Overwrite Entries
Use this parameter with the value true to specify that group information loaded from the URI should overwrite existing group information. The default value is false , specifying that group information loaded from the URI should not overwrite existing group information.
[-skip-name-validation {true|false}] - Skip Name Validation
By default, Data ONTAP validates the name to ensure it complies with the following rules:
  • The name contains only valid characters: 0 through 9, A through Z, a through z, "_", ".", and "-"
  • The name does not start with "-"
  • The name does not contain "$" except as the last character
If the parameter is set to true , the name validation is skipped.
[-foreground {true|false}] - Load Unix Groups file in the Foreground
If this parameter is set to false , the operation runs as a job in the background. Otherwise, the command does not return until the operation is complete. The default value is true .
The following example loads group information from the URI ftp://ftp.example.com/groups onto a Vserver named vs0:
cluster1::> vserver services name-service unix-group load-from-uri -vserver vs0 -uri ftp://ftp.example.com/groups
