job schedule interval modify
Modify an interval schedule
The job schedule interval modify command modifies an interval schedule. An interval schedule runs jobs at a specified interval after the previous job finishes. Use the job schedule interval show command to display all current interval schedules. See the documentation of job schedule interval show for more information on how interval schedules work.
Modifying one parameter of a schedule's interval does not affect the other parameters. For example, if a schedule's interval is 1 day 12 hours, and you modify the "hours" parameter to 16, the schedule's new interval is 1 day 16 hours. To clear a parameter of the schedule's interval, you must explicitly set that parameter to "0" or "-".
[-cluster <Cluster name>]- Cluster-
Use this parameter to specify the cluster of an existing interval schedule you want to modify. The local cluster is provided as the default value. In a MetroCluster configuration, the partner cluster can be specified if the local cluster is in switchover state.
 -name <text>- Name-
Use this parameter with the name of an existing interval schedule to specify the interval schedule you want to modify.
 [-days <integer>]- Days-
Use this parameter to specify a different "days" value for the schedule's interval.
 [-hours <integer>]- Hours-
Use this parameter to specify a different "hours" value for the schedule's interval.
 [-minutes <integer>]- Minutes-
Use this parameter to specify a different "minutes" value for the schedule's interval.
 [-seconds <integer>]- Seconds-
Use this parameter to specify a different "seconds" value for the schedule's interval.
The following example sets the schedule named rollingdaily to run every eight hours:
cluster1::> job schedule interval modify -name rollingdaily -hours 8
