system configuration backup show
Show configuration backup information
The system configuration backup show command displays information about saved configuration backups.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node (privilege: advanced)
Selects configuration backups that are saved on the node you specify.
- [-backup <text>]- Backup Name (privilege: advanced)
Selects configuration backups that have the backup name you specify.
- [-backup-type {node|cluster}]- Backup Type (privilege: advanced)
Selects configuration backups of the type you specify.
- [-time <MM/DD HH:MM:SS>]- Backup Creation Time (privilege: advanced)
Selects configuration backups that were saved on the date and time you specify.
- [-cluster-name <text>]- Cluster Name (privilege: advanced)
Selects configuration backups that were saved in the cluster that has the name you specify.
- [-cluster-uuid <UUID>]- Cluster UUID (privilege: advanced)
Selects configuration backups that were saved in the cluster that has the UUID you specify.
- [-size {<integer>[KB|MB|GB|TB|PB]}]- Size of Backup (privilege: advanced)
Selects configuration backups that have the file size you specify.
- [-nodes-in-backup {<nodename>|local}]- Nodes In Backup (privilege: advanced)
Selects configuration backups that include the configuration of the nodes you specify.
- [-version <text>]- Software Version (privilege: advanced)
Selects configuration backups that have the software version you specify.
- [-is-auto {true|false}]- Backup Created from Schedule (true or false) (privilege: advanced)
A value of true selects configuration backups that were created from a schedule. A value of false selects configuration backups that were created manually.
- [-schedule <text>]- Name of Backup Schedule (privilege: advanced)
Selects configuration backups that were created by the schedule you specify.
The following example shows typical output for this command.
cluster1::*> system configuration backup show Node Backup Tarball Time Size --------- ----------------------------------------- ------------------ ----- node1 cluster1.8hour.2011-02-22.18_15_00.7z 02/22 18:15:00 7.78MB node1 cluster1.8hour.2011-02-23.02_15_00.7z 02/23 02:15:00 7.98MB node1 cluster1.8hour.2011-02-23.10_15_00.7z 02/23 10:15:00 7.72MB node1 cluster1.daily.2011-02-22.00_10_00.7z 02/22 00:10:00 7.19MB node1 cluster1.daily.2011-02-23.00_10_00.7z 02/23 00:10:00 7.99MB Press <space> to page down, <return> for next line, or 'q' to quit... q 5 entries were displayed.
 PDFs
PDFs
