lun igroup initiator show
Display initiators
This command displays information for initiators that are members of initator groups (igroups).
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver-
Selects the initiators of igroups whose Vserver matches the specified value.
 [-initiator <text>]- Initiator-
Selects initiators whose name matchs the specified value.
 [-comment <text>]- Comment-
Selects initiators whose comment matchs the specified value.
 [-igroups <text>,…]- Igroups-
Selects initiators belonging to the specified igroups.
cluster1::> lun igroup initiator show -instance Vserver: vs0 Initiator: init1 Comment: Initiator Comment Igroups: ig1,ig2 Vserver: vs0 Initiator: init2 Comment: Initiator Comment2 Igroups: ig3 2 entries were displayed.
This example displays detailed information for all initiators in igroups.
