ONTAP commands
lun igroup initiator show
Display initiators
This command displays information for initiators that are members of initator groups (igroups).
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver
Selects the initiators of igroups whose Vserver matches the specified value.
[-initiator <text>] - Initiator
Selects initiators whose name matchs the specified value.
[-comment <text>] - Comment
Selects initiators whose comment matchs the specified value.
[-igroups <text>,…​] - Igroups
Selects initiators belonging to the specified igroups.
cluster1::> lun igroup initiator show -instance
  Vserver: vs0
Initiator: init1
  Comment: Initiator Comment
  Igroups: ig1,ig2
Vserver: vs0
Initiator: init2
  Comment: Initiator Comment2
  Igroups: ig3
2 entries were displayed.
This example displays detailed information for all initiators in igroups.
