lun igroup initiator show
PDF of this doc site
Creating your file...
Display initiators
This command displays information for initiators that are members of initator groups (igroups).
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver-
Selects the initiators of igroups whose Vserver matches the specified value.
[-initiator <text>]
- Initiator-
Selects initiators whose name matchs the specified value.
[-comment <text>]
- Comment-
Selects initiators whose comment matchs the specified value.
[-igroups <text>,…]
- Igroups-
Selects initiators belonging to the specified igroups.
[-proximal-vservers <text>,…]
- Proximal Vservers (privilege: advanced)-
Selects initiators configured as proximal to the specified Vservers.
cluster1::> lun igroup initiator show -instance Vserver: vs0 Initiator: init1 Comment: Initiator Comment Igroups: ig1,ig2 Vserver: vs0 Initiator: init2 Comment: Initiator Comment2 Igroups: ig3 2 entries were displayed.
This example displays detailed information for all initiators in igroups.
