      system services ndmp node-scope-mode status
(DEPRECATED)-Status of NDMP node-scope-mode
This node-scoped NDMP command is deprecated. Node-scoped NDMP functionality may be removed in a future release of Data ONTAP. Use the Vserver-aware "`vserver services ndmp` " command. |
This command displays whether the NDMP server is operating in node-scope-mode or not.
NDMP node-scope-mode is disabled - NDMP server is Vserver-aware
NDMP node-scope-mode is enabled - NDMP server is node scoped
The following example shows how to check the status of NDMP server in a cluster
cluster1::> system services ndmp node-scope-mode status NDMP node-scope-mode is disabled.
