security certificate ca-issued show
Display CA-Issued Digital Certificates
This command displays the following information about the digital certificates issued by the self-signed root-ca:
Vserver
Serial number of certificate
FQDN or custom common name or the name of a person
Serial number of CA certificate
Status (
active, revoked) -
Certificate Authority
Expiration date
Revocation date
To display more details, run the command with the -instance parameter. This will add the following information:
Country name
State or province name
Locality name
Organization name
Organization unit
Contact administrator's email address
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Name of Vserver-
Selects the certificates that match this parameter value.
[-serial <text>]- Serial Number of Certificate-
[-ca <text>]- Certificate Authority-
[-ca-serial <text>]- Serial Number of CA Certificate-
[-common-name <FQDN or Custom Common Name>]- FQDN or Custom Common Name-
[-status <status of certificate>]- Status of Certificate-
Selects the certificates that match this parameter value. Possible values include active and revoked.
[-expiration <Date>]- Certificate Expiration Date-
[-revocation <Date>]- Certificate Revocation Date-
[-country <text>]- Country Name (2 letter code)-
[-state <text>]- State or Province Name (full name)-
[-locality <text>]- Locality Name (e.g. city)-
[-organization <text>]- Organization Name (e.g. company)-
[-unit <text>]- Organization Unit (e.g. section)-
[-email-addr <mail address>]- Email Address (Contact Name)-
The examples below display information about CA issued digital certificates.
cluster1::> security certificate ca-issued show
Serial Number of
Vserver Serial Number Common Name CA's Certificate Status
vs0 4F5A2C90 example.com 4F4EB629 active
Certificate Authority: vs0.cert
Expiration Date: Sat Apr 14 16:15:13 2012
Revocation Date: -
vs0 4F5A2DF2 example.com 4F4EB629 revoked
Expiration Date: Sat Apr 14 16:21:06 2012
Revocation Date: Fri Mar 09 17:08:30 2012
2 entries were displayed.
cluster1::> security certificate ca-issued show -instance
Vserver: vs0
Serial Number of Certificate: 4F5A2C90
Serial Number of CA Certificate: 4F4EB629
FQDN or Custom Common Name: example.com
Status of Certificate: active
Certificate Expiration Date: Sat Apr 14 16:15:13 2012
Certificate Revocation Date: -
Country Name (2 letter code): US
State or Province Name (full name): California
Locality Name (e.g. city): Sunnyvale
Organization Name (e.g. company): example
Organization Unit (e.g. section): IT
Email Address (Contact Name): web@example.com
