security certificate ca-issued show
Display CA-Issued Digital Certificates
This command displays the following information about the digital certificates issued by the self-signed root-ca:
Vserver
Serial number of certificate
FQDN or custom common name or the name of a person
Serial number of CA certificate
Status (
active, revoked
Certificate Authority
Expiration date
Revocation date
To display more details, run the command with the -instance
parameter. This will add the following information:
Country name
State or province name
Locality name
Organization name
Organization unit
Contact administrator's email address
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Name of Vserver-
Selects the certificates that match this parameter value.
[-serial <text>]
- Serial Number of Certificate-
[-ca <text>]
- Certificate Authority-
[-ca-serial <text>]
- Serial Number of CA Certificate-
[-common-name <FQDN or Custom Common Name>]
- FQDN or Custom Common Name-
[-status <status of certificate>]
- Status of Certificate-
Selects the certificates that match this parameter value. Possible values include active and revoked.
[-expiration <Date>]
- Certificate Expiration Date-
[-revocation <Date>]
- Certificate Revocation Date-
[-country <text>]
- Country Name (2 letter code)-
[-state <text>]
- State or Province Name (full name)-
[-locality <text>]
- Locality Name (e.g. city)-
[-organization <text>]
- Organization Name (e.g. company)-
[-unit <text>]
- Organization Unit (e.g. section)-
[-email-addr <mail address>]
- Email Address (Contact Name)-
The examples below display information about CA issued digital certificates.
cluster1::> security certificate ca-issued show Serial Number of Vserver Serial Number Common Name CA's Certificate Status ---------- --------------- --------------------------- ---------------- ------- vs0 4F5A2C90 example.com 4F4EB629 active Certificate Authority: vs0.cert Expiration Date: Sat Apr 14 16:15:13 2012 Revocation Date: - vs0 4F5A2DF2 example.com 4F4EB629 revoked Certificate Authority: vs0.cert Expiration Date: Sat Apr 14 16:21:06 2012 Revocation Date: Fri Mar 09 17:08:30 2012 2 entries were displayed.
cluster1::> security certificate ca-issued show -instance Vserver: vs0 Serial Number of Certificate: 4F5A2C90 Certificate Authority: vs0.cert Serial Number of CA Certificate: 4F4EB629 FQDN or Custom Common Name: example.com Status of Certificate: active Certificate Expiration Date: Sat Apr 14 16:15:13 2012 Certificate Revocation Date: - Country Name (2 letter code): US State or Province Name (full name): California Locality Name (e.g. city): Sunnyvale Organization Name (e.g. company): example Organization Unit (e.g. section): IT Email Address (Contact Name): web@example.com
