ONTAP commands
vserver audit disable
Disable auditing
The vserver audit disable command disables auditing for a Vserver.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver for which auditing is to be disabled. The Vserver audit configuration must already exist.
The following example disables auditing for Vserver vs1.
cluster1::> vserver audit disable -vserver vs1
