      template provision
Provision Data ONTAP resources using the template
The command template provision provisions ONTAP system based on the template that is passed as an input to the template parameter. A wizard is presented which will accept the required inputs.
-name <template name>- Name of the template-
This parameter specifies the name of the template
 [-simulate {true|false}]- Simulate-
If this parameter is specified, the provisioning is just simulated and there will be no changes done to the system.
The following example provisions a vserver with required protocols using template.
cluster-1::> template provision -name VserverEnvironmentSetup
      Press Ctrl+C to abort.
      * Setup of vserver *
      Vserver Name: vs0
      Vserver Language [C.UTF-8]:
      Vserver Security Style [unix]:
      Vserver IPSpace [Default]:
      * Setup of network.interface *
      Enter number of instances for object network.interface: 2
      (1/2)LIF Protocol: nfs
      (1/2)IP Addr: 1.1.1.1
      (1/2)NetMask: 255.255.255.0
      (1/2)Node Name: node1-vsim1
      (1/2)Port: e0c
      (2/2)LIF Protocol: nfs
      (2/2)IP Addr: 1.1.1.1
      (2/2)NetMask: 255.255.255.0
      (2/2)Node Name: node1-vsim1
      (2/2)Port: e0c
      * Setup of network.routes *
      Enter number of instances for object network.routes: 1
      (1/1)Gateway: 1.1.1.1
      * Setup of access.dns *
      Search Domain: netapp.com
      DNS IP Addresses List: 1.1.1.1
      * Setup of security.nis *
      NIS Domains: netapp.com
      NIS IP Address: 1.1.1.1
      * Setup of security *
      LDAP Client Config: ldapconfig
      LDAP Server IP: 1.1.1.1
      LDAP Base DN: dc=examplebasedn
      * Setup of protocols *
      Protocols to configure: nfs
      [Job 15] Configuring vserver for vs0 (100%)
