template provision
PDF of this doc site
Creating your file...
Your file is ready
Provision Data ONTAP resources using the template
The command template provision
provisions ONTAP system based on the template that is passed as an input to the template parameter. A wizard is presented which will accept the required inputs.
-name <template name>
- Name of the template-
This parameter specifies the name of the template
[-simulate {true|false}]
- Simulate-
If this parameter is specified, the provisioning is just simulated and there will be no changes done to the system.
The following example provisions a vserver with required protocols using template.
cluster-1::> template provision -name VserverEnvironmentSetup Press Ctrl+C to abort. ******************** * Setup of vserver * ******************** Vserver Name: vs0 Vserver Language [C.UTF-8]: Vserver Security Style [unix]: Vserver IPSpace [Default]: ****************************** * Setup of network.interface * ****************************** Enter number of instances for object network.interface: 2 (1/2)LIF Protocol: nfs (1/2)IP Addr: 1.1.1.1 (1/2)NetMask: 255.255.255.0 (1/2)Node Name: node1-vsim1 (1/2)Port: e0c (2/2)LIF Protocol: nfs (2/2)IP Addr: 1.1.1.1 (2/2)NetMask: 255.255.255.0 (2/2)Node Name: node1-vsim1 (2/2)Port: e0c *************************** * Setup of network.routes * *************************** Enter number of instances for object network.routes: 1 (1/1)Gateway: 1.1.1.1 *********************** * Setup of access.dns * *********************** Search Domain: netapp.com DNS IP Addresses List: 1.1.1.1 ************************* * Setup of security.nis * ************************* NIS Domains: netapp.com NIS IP Address: 1.1.1.1 ********************* * Setup of security * ********************* LDAP Client Config: ldapconfig LDAP Server IP: 1.1.1.1 LDAP Base DN: dc=examplebasedn ********************** * Setup of protocols * ********************** Protocols to configure: nfs [Job 15] Configuring vserver for vs0 (100%)
