cluster controller-replacement network displaced-vlans restore
Delete VLANs displaced by controller-replacement
Restore VLAN tags that were displaced due to a controller-replacement. A VLAN tag that has been displaced is a tag that was based on a network port that either no longer exists, or was moved to a new broadcast domain. Restoring the vlan-tags re-creates them on the specified network port.
-node <nodename> - Node
Selects the node on which the displaced vlans reside.
-port <netport> - Original Base Port
The original base port where the vlans existed prior to controller-replacement.
-destination-port <netport> - Destination Port
The destination port where the vlan-tags will be restored.
The following example restores vlan-tags displaced from port e0c onto port e0d.
cluster1::> cluster controller-replacement network displaced-vlans restore -node node1 -port e0c -destination-port e0d
