volume inode-upgrade prepare-to-downgrade
PDF of this doc site
Creating your file...
Your file is ready
Prepare volume to downgrade to a release earlier than Data ONTAP 9.0.0
The volume inode-upgrade prepare-to-downgrade
command prepares volumes to downgrade to a release earlier than Data ONTAP 9.0.0. It is used when there are still volumes in the middile of the inode upgrade process when revert is issued.
-node {<nodename>|local}
- Node Name (privilege: advanced)-
This specifies the node on which the command will run. Default is the local node.
The following example prepares volumes to revert to an earlier release.
cluster1::> volume inode-upgrade prepare-to-downgrade -node node1
