      network options multipath-routing modify
Modify multipath-routing
The network options multipath-routing modify command is used to modify cluster-wide multipath routing configuration.
[-is-enabled {true|false}]- Is Multipath Routing Enabled (privilege: advanced)-
This parameter specifies whether multipath routing configuration is enabled or not. Setting this parameter to
_ true_enables multipath routing for all nodes in the cluster.
cluster1::> network options multipath-routing modify -is-enabled true
