vserver vscan connection-status show-not-connected
Display connection status of Vscan servers which are allowed to connect but not yet connected
The vserver vscan connection-status show-not-connected command displays connection status information of the external virus-scanning servers, or "Vscan servers" that are ready to accept connection but are not yet connected. This command could be useful for troubleshooting. If you do not specify any parameters, the command displays the following information for all Vscan servers:
  • Vserver name
  • Node name
  • Vscan server
  • Connection status
  • Disconnect reason
You can specify the -fields parameter to specify which fields of information to display. In addition to the fields above, you can display the following fields:
  • Server type
  • Vscan server disconnected since
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
If you specify this parameter, the command displays information only about the Vscan servers attached to the specified node.
[-vserver <vserver name>] - Vserver
If you specify this parameter, the command displays information only about the Vscan servers for the specified Vserver.
[-server <IP Address>] - Server
If you specify this parameter, the command displays information only about the Vscan server that you specify.
[-server-status <Status>] - Server Status
If you specify this parameter, the command displays information only about the Vscan servers that have the specified status.
[-disconnect-reason <reason>] - Server Disconnect Reason
If you specify this parameter, the command displays information only about the Vscan servers that are disconnected because of the specified reason.
[-disconnected-since <MM/DD/YYYY HH:MM:SS>] - Time When Vscan Server Was Disconnected
If you specify this parameter, the command displays information only about the Vscan servers that have been disconnected since the specified time.
[-server-type <Server type>] - Server Type
If you specify this parameter, the command displays information only about the Vscan servers that have the specified server type.
The following example displays connection-status information about all Vscan servers which are ready to accept connection but not yet connected.
cluster1::> vserver vscan connection-status show-not-connected
                                                 Connection    Disconnect
Vserver       Node              Server           Status        Reason
vs2           Cluster-01        3.3.3.3          disconnected  invalid-
                                                               session-id
vs2           Cluster-01        4.4.4.4          disconnected  remote-closed
2 entries were displayed.
The following example displays detailed connection-status information about Vscan servers which are disconnected because the connection is remotely closed.
cluster1::> vserver vscan connection-status show-not-connected -instance
            -disconnect-reason remote-closed
Node: Cluster-01
                            Vserver: vs2
                             Server: 4.4.4.4
                      Server Status: disconnected
           Server Disconnect Reason: remote-closed
Time When Vscanner Was Disconnected: 6/4/2013 06:51:32
                        Server Type: primary
