vserver vscan connection-status show-not-connected
Display connection status of Vscan servers which are allowed to connect but not yet connected
The vserver vscan connection-status show-not-connected
command displays connection status information of the external virus-scanning servers, or "Vscan servers" that are ready to accept connection but are not yet connected. This command could be useful for troubleshooting. If you do not specify any parameters, the command displays the following information for all Vscan servers:
Vserver name
Node name
Vscan server
Connection status
Disconnect reason
You can specify the -fields
parameter to specify which fields of information to display. In addition to the fields above, you can display the following fields:
Server type
Vscan server disconnected since
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
If you specify this parameter, the command displays information only about the Vscan servers attached to the specified node.
[-vserver <vserver name>]
- Vserver-
If you specify this parameter, the command displays information only about the Vscan servers for the specified Vserver.
[-server <IP Address>]
- Server-
If you specify this parameter, the command displays information only about the Vscan server that you specify.
[-server-status <Status>]
- Server Status-
If you specify this parameter, the command displays information only about the Vscan servers that have the specified status.
[-disconnect-reason <reason>]
- Server Disconnect Reason-
If you specify this parameter, the command displays information only about the Vscan servers that are disconnected because of the specified reason.
[-disconnected-since <MM/DD/YYYY HH:MM:SS>]
- Time When Vscan Server Was Disconnected-
If you specify this parameter, the command displays information only about the Vscan servers that have been disconnected since the specified time.
[-server-type <Server type>]
- Server Type-
If you specify this parameter, the command displays information only about the Vscan servers that have the specified server type.
The following example displays connection-status information about all Vscan servers which are ready to accept connection but not yet connected.
cluster1::> vserver vscan connection-status show-not-connected Connection Disconnect Vserver Node Server Status Reason ------------- ----------------- ---------------- ------------- --------------- vs2 Cluster-01 3.3.3.3 disconnected invalid- session-id vs2 Cluster-01 4.4.4.4 disconnected remote-closed 2 entries were displayed.
The following example displays detailed connection-status information about Vscan servers which are disconnected because the connection is remotely closed.
cluster1::> vserver vscan connection-status show-not-connected -instance -disconnect-reason remote-closed Node: Cluster-01 Vserver: vs2 Server: 4.4.4.4 Server Status: disconnected Server Disconnect Reason: remote-closed Time When Vscanner Was Disconnected: 6/4/2013 06:51:32 Server Type: primary
