volume flexcache prepare-to-downgrade
Disables flexcache version features
This command disables the FlexCache feature enabled for a version.
[-disable-feature-set <ClusterVersion>]
- Cluster Version (privilege: advanced)-
This specifies the version for which we are running this command.
The following example disables FlexCache features for cluster "cluster1":
cluster1::> flexcache prepare-to-downgrade -disable-feature-set 9.8.0 FlexCache features introduced in 9.8 are successfully disabled.
