The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume flexcache prepare-to-downgrade
PDF of this doc site
Creating your file...
Your file is ready
Disables flexcache version features
This command disables the FlexCache feature enabled for a version.
[-disable-feature-set <ClusterVersion>]
- Cluster Version (privilege: advanced)-
This specifies the version for which we are running this command.
The following example disables FlexCache features for cluster "cluster1":
cluster1::> flexcache prepare-to-downgrade -disable-feature-set 9.8.0 FlexCache features introduced in 9.8 are successfully disabled.
