lun portset show
PDF of this doc site
Creating your file...
Displays a list of portsets
This command displays the LIFs in a portset. By default, the command displays all LIFs in all portsets.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver Name-
Selects the portsets that match this parameter value.
[-portset <text>]
- Portset Name-
[-uuid <UUID>]
- Portset Uuid-
[-port-name <port_name>,…]
- LIF Or TPG Name-
[-protocol {mixed|fcp|iscsi}]
- Protocol-
[-port-count <integer>]
- Number Of Ports-
[-igroups <igroup>,…]
- Bound To Igroups-
cluster1::> lun portset show Vserver Portset Protocol Port Names Igroups --------- ------------ -------- ----------------------- ------------ vs1 ps0 mixed lif1, lif2 igroup1 ps1 iscsi lif3 igroup2 ps2 fcp lif4 - 3 entries were displayed.
The example above displays all portsets.
cluster1::> lun portset show -port-count 0 Vserver Portset Protocol Port Names Igroups --------- ------------ -------- ----------------------- ------------ vs1 p1 iscsi - -
The example above displays the portsets that contain zero LIFs.
cluster1::> lun portset show -protocol iscsi Vserver Portset Protocol Port Names Igroups --------- ------------ -------- ----------------------- ------------ vs1 p1 iscsi - - vs1 iscsips iscsi lif1 igroup1 2 entries were displayed.
The example above displays the portsets that have the iSCSI protocol.
cluster1::> lun portset show -port-name lif1 Vserver Portset Protocol Port Names Igroups --------- ------------ -------- ----------------------- ------------ vs1 iscsips iscsi lif1 igroup1
The example above displays the portsets that contain LIF lif1.
