The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
security anti-ransomware volume resume
PDF of this doc site
Creating your file...
Your file is ready
Resume anti-ransomware on a volume
The security anti-ransomware volume resume
command resumes Anti-ransomware monitoring on a volume.
-vserver <vserver name>
- Vserver Name-
Anti-ransomware monitoring is resumed on volumes that match the values for the Vserver and volume parameters. If only one data Vserver exists, you do not need to specify this parameter.
-volume <volume name>
- Volume Name-
Anti-ransomware monitoring is resumed on volumes matching the parameter value.
