security saml-sp create
Configure SAML service provider for authentication
The security saml-sp create command configures ONTAP with Security Assertion Markup Language (SAML) Service Provider (SP) for single sign-on authentication. This command does not enable SAML SP, it just configures it. Configuring and enabling SAML SP is a two-step process:
Create a SAML SP configuration using security saml-sp createcommand.
Enable SAML SP by using security saml-sp modify -is-enabledtrue
After the SAML SP configuration is created, it cannot be modified. It must be deleted and created again to change any settings.
|  | This restarts the web server. Any HTTP/S connections that are active will be disrupted. |
- -idp-uri {(ftp|http|https)://(hostname|IPv4 Address|'['IPv6 Address']')…}- Identity Provider (IdP) Metadata Location
This is the URI of the desired identity provider's (IdP) metadata.
- [-sp-host <Remote InetAddress>]- SAML Service Provider Host
This specifies the SAML service provider host IP address.
- { -cert-ca <text>- Server Certificate Issuing CA
This specifies the service provider's certificate issuing CA.
- -cert-serial <text>- Server Certificate Serial Number
This specifies the service provider's certificate's serial number.
- | [-cert-common-name <FQDN or Custom Common Name>]- Server Certificate Common Name }
This specifies the service provider certificate's common name.
- [-verify-metadata-server {true|false}]- Verify IdP Metadata Server Identity
When the IdP metadata is downloaded, the identity of the server hosting the metadata is verified using transport layer security (TLS), validating the server's X.509 certificate against the list of certificate authorities (CAs) in Data ONTAP, and verifying that the host in the server certificate matches the host in the URI (the idp-urifield). This verification can be bypassed by setting this field tofalse. Bypassing the server verification is not recommended as the server can not be trusted that way, but will be necessary to use non-TLS URIs, e.g. with the "http" scheme, or when the server certificates are self-signed. If the server's certificate was signed by a CA that is not installed in Data ONTAP, the security certificate install -type server-ca command can be used to install it.
- [-foreground {true|false}]- Foreground Process
When this parameter is set to falsethe command runs in the background as a job. The default istrue, which causes the command to return after the operation completes.
The following example configures ONTAP with SAML SP IdP information:
cluster1::> security saml-sp create -idp-uri http://public-idp-uri -sp-host 1.1.1.1
    [Job 9] Job succeeded.
    cluster1::>
 PDFs
PDFs
