      network ipspace show
Display IPspace information
Display network IPspaces.
[-fields <fieldname>,…] -
Specify the fields to be displayed for each IPspace.
[-instance ]} -
Display all parameters of the IPspace objects.
 [-ipspace <IPspace>]- IPspace name-
Display the names of the IPspaces.
 [-ports [node>:<port],…]- Ports-
The list of network ports assigned to each IPspace.
 [-broadcast-domains <Broadcast Domain>,…]- Broadcast Domains-
The list of broadcast domains that belong to the IPspace.
 [-vservers <vserver name>,…]- Vservers-
The list of Vservers assigned to each IPspace.
The following example displays general information about IPspaces.
cluster1::> network ipspace show
IPspace             Vserver List                  Broadcast Domains
Cluster
                    Cluster                       -
Default
                    cluster1, vs1, vs2            br1, br2, br3
2 entries were displayed.
