network ipspace show
Display IPspace information
Display network IPspaces.
[-fields <fieldname>,…]
Specify the fields to be displayed for each IPspace.
[-instance ]
Display all parameters of the IPspace objects.
[-ipspace <IPspace>]
- IPspace name-
Display the names of the IPspaces.
[-ports [node>:<port],…]
- Ports-
The list of network ports assigned to each IPspace.
[-broadcast-domains <Broadcast Domain>,…]
- Broadcast Domains-
The list of broadcast domains that belong to the IPspace.
[-vservers <vserver name>,…]
- Vservers-
The list of Vservers assigned to each IPspace.
The following example displays general information about IPspaces.
cluster1::> network ipspace show IPspace Vserver List Broadcast Domains ------------------- ----------------------------- ---------------------------- Cluster Cluster - Default cluster1, vs1, vs2 br1, br2, br3 2 entries were displayed.
