Command reference
network ipspace show
Display IPspace information
Display network IPspaces.
{ [-fields <fieldname>,…​]
Specify the fields to be displayed for each IPspace.
| [-instance ] }
Display all parameters of the IPspace objects.
[-ipspace <IPspace>] - IPspace Name
Display the names of the IPspaces.
[-ports [node>:<port],…​] - Ports
The list of network ports assigned to each IPspace.
[-broadcast-domains <Broadcast Domain>,…​] - Broadcast Domains
The list of broadcast domains that belong to the IPspace.
[-vservers <vserver name>,…​] - Vservers
The list of Vservers assigned to each IPspace.
[-tcp-stack {freebsd|rack}] - TCP Stack Name (privilege: advanced)
Display the TCP stack name used by IPspace.
The following example displays general information about IPspaces.
cluster1::> network ipspace show
IPspace             Vserver List                  Broadcast Domains
Cluster
                    Cluster                       -
Default
                    cluster1, vs1, vs2            br1, br2, br3
2 entries were displayed.
