ONTAP 9.13.1 commands
network options port-health-monitor enable-monitors
Enable one or more port health monitors
This command enables the given port health monitors for the given IPspaces in the cluster.
-ipspace <IPspace> - IPspace Name (privilege: advanced)
The name of the IPspace for which the specified port health monitors are enabled.
-health-monitors {l2-reachability|link-flapping|crc-errors|vswitch-link} - List of Port Health Monitors to Enable (privilege: advanced)
The port health monitors to enable. Upon enabling the l2_reachability health monitor, it runs in an "unpromoted" state. While in this state, the monitor does not mark any ports as unhealthy due to the l2_reachability health check. The monitor is promoted in the "Cluster" IPspace when the "Cluster" broadcast domain is found to have passed the l2_reachability health check. An EMS event called "vifmgr.hm.promoted" event is generated when the health monitor is promoted for the IPspace.
The following example enables the "l2_reachability" health monitor for the "Default" IPspace:
Note The status of the "link_flapping" monitor is unaffected by the command.
cluster1::*> network options port-health-monitor show
IPspace         Enabled Port Health Monitors
Cluster         l2_reachability,
                link_flapping
Default         link_flapping
2 entries were displayed.
cluster1::*> network options port-health-monitor enableMonitors -ipspace Default -health-monitors l2_reachability
                link_flapping
Default         l2_reachability,
                link_flapping
