vserver nvme subsystem show
PDF of this doc site
Creating your file...
Display NVMe target subsystems
The vserver nvme subsystem show
command displays information for NVMe subsystems.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver Name-
Use this parameter to display the NVMe subsystems that match the Vserver that you specify.
[-subsystem <text>]
- Subsystem-
Use this parameter to display the NVMe subsystem that matches the name that you specify.
[-ostype {aix|linux|vmware|windows}]
- OS Type-
Use this parameter to display the NVMe subsystems that match this parameter value.
[-comment <text>]
- Comment-
[-target-nqn <text>]
- Target NQN-
[-serial-number <text>]
- Serial Number-
[-default-io-queue-count <integer>]
- Default Number of Host I/O Queue Pairs-
Specifies the IO queue count inherited by hosts added to this subsystem. The actual value used when a connection is established may vary depending on the host and transport protocol used.
[-default-io-queue-depth <integer>]
- Default Host I/O Queue Depth-
Specifies the IO queue depth inherited by hosts added to this subsystem. The actual value used when a connection is established may vary depending on the host and transport protocol used.
[-uuid <UUID>]
- UUID-
Use this parameter to display the NVMe subsystems that have UUIDs matching the parameter value.
[-delete-on-unmap {true|false}]
- Delete on Unmap (privilege: advanced)-
Specifies whether the subsystem should be deleted automatically when it is no longer mapped to a namespace.
[-vendor-uuids <UUID>,…]
- Vendor UUIDs (privilege: advanced)-
Use this parameter to display the NVMe subsystems that have vendor-specific UUIDs that match the parameter value.
cluster1::*> vserver nvme subsystem show -vserver vs_1 Vserver Subsystem Target NQN ------- ------------ -------------------------------------------------------- vs_1 ss1 nqn.1992-08.netapp.com:sn.ccb5a7d5d9d311e7924e005056b45113:subsystem.ss1 ss2 nqn.1992-08.netapp.com:sn.ccb5a7d5d9d311e7924e005056b45113:subsystem.ss2 2 entries were displayed.
